You can access the switch as needed through the command line interface.
The switch is accessible using the following connectors:
For more information on the console port pinouts, see the hardware installation guide for your switch.After the connection is established, you will see the switch prompt and can now log in.
The CLI is limited for 4000 Series devices. See the 4000 Series User Guide for this version of Switch Engine for detailed information on the available commands.
